Router behind router
helio58
Two lans talking both ways.
Lan A - Asus AC68 with merlin lan 192.168.1.1 connect to wan
In settings lan route - I add 192.168.2.1 255.255.255.0 gateway 192.168.1.10 metric 2 Lan
LanB - Asus AC86 with merlin lan 192.168.2.1 connect to lan port 4 fast ip 192.168.1.10
Firewall off
LanB I can connect to all computers on LanA.
LanB computer 192.168.2.55
I can't access computer 192.168.2.55 from Lan A any idea what I m missing?
With your current setup everything on LanB is being NATed. So any unsolicited incoming traffic will need to have a port forwarding rule. However, as this is an internal network I suggest that you just turn off NAT on router B. Then it should work without the need for port forwarding.
Thanks Colin, I turn off Nat on router B . Then I can't access to the internet from network B .
Still cannot connect from A to B.
I can't think why you would lose internet connectivity when you turn off NAT on router B.
Maybe there's something I'm not seeing. Can you draw a diagram of your network. Do you have anything non-default on router B, like VPN's, guest networks, DNSFilter, DHCP, etc.?
Plug the cable from router A lan port into router B lan port. Don't use the Wan port on router B for the connection.
That's a bad idea unless he reconfigures router B as an access point (in which case he can still use its WAN port because it becomes another LAN port).
I do this all the time
Only difference is that I want my router to block everything instead using it as a switch...
Anyway
On router A you use dmz to fixed ip on router B
Router B need to be configured with 2 routing settings
First is the ip range of router A. Else he won’t find it
Second for range B. Same reason
Now if you want router A to access subnet of router B you do the same on router A
I hope you manual configure the ip addresses instead using dhcp ?
As 2 dhcp servers gives conflicts if you broadcast on both sub nets ( what is needed to access both networks )
Greets from PowerChaos
Verzonden vanaf mijn iPhone met Tapatalk
This is not necessary as the default route on Router B is all that is needed.
Again, this is not needed because DHCP is broadcast traffic and doesn't route across subnets.
Here is the setup
ISP---->Router A---RT-AC68U DHCP on 192.168.1.1 ----cabel from Lan to Router B-- RT-AC86U-Wan Port
Router B gets fast ip from router A 192.168.1.10---- Router B dhcp on 192.168.2.1
Turning Nat off no internet
No vpn , no guest networks
DNSFilter off
DHCP on
Sorry, I think there's a translation problem. I don't understand what you are saying here.
When NAT is off can you ping or connect to devices on 192.168.1.x from a device on 192.168.2.x?
What are the LAN subnet masks for both routers, 255.255.255.0?
No I can't .
In network charts its the ip I see it says wan port ip
Sorry for the bad English
No I can't .
Is it “fast” as in “static” or “unchanging” or “fixed”?
