Router for range and load
charlieboy246
Hi there everybody I am currently in the market for a new router and after having done much research I am still in confusion into which router I should purchase.
I really want a router that has great range as my current BT Home Hub 4 has okay range. My property is a medium sized 2 floor house with medium size thick hardwood walls.
At any point I have 20 or so devices connected including wireless and wired connections.
I have looked at the R7000 and the AC87u but there are many negative and positive reviews on Amazon about both these products therefore I am conflicted.
My main aim however is range therefore please can you suggest me a router that has great range.
Budget is around £150
Thank you very much
The R7000 is stable and mature with good 3rd party support - also consider that the R7000 is part of the SNB router test platform, which says much about the stability of this device...
The Asus RT-AC87U is the poster child for excess frustration on the part of many forum members - it's an evolutionary dead-end as Asus has moved on from their Quantenna experiment...
