Router seems to have been hacked and I can't change it?
mrmotivator
Hello,
I've got the RT-N66U router which I normally access via a static IP, however when I tried to access it using the h t t p : / / w w w .asusnetwork.net URL today, it tried redirecting me to this page (DO NOT CLICK THIS):
h t t p : / / fastrdr.com/us/65/index.php?s=220256201
This was detected as a thread and stopped by my antivirus:
It also seems to redirect to this page (ALSO DO NOT CLICK): http://ww1.asusnetwork.net/
Which looks like this:
The closest thing I can find about it is here: http://www.kb.cert.org/vuls/id/191750
However this is for a different router and just says to make sure I've got the most recent firmware, which I regularly check for and install as soon as it's available (I'm definitely on the most recent version, 3.0.0.4.374.5517).
I just have a few questions :)
  • How can I fix it?
  • What has caused it? (Is it machine or router based?)
  • How can I prevent it from happening again?
  • What effects will it have had other than the redirection?
Thanks for your help :)
(EDIT: Un-linked the malicious URL to avoid accidents and forum blacklisting. --RMerlin)
Most likely reason is you have a DNS hijacker installed on your computer.
Download and run Malwarebytes Antimalware, and do a complete scan with it. Also double check that your computer is using your router's IP for DNS and not something else. Also check the content of C:\Windows\System32\drivers\etc\hosts for the presence of any suspicious IP (normally there's only one entry for the 127.0.0.1 loopback).
Also check what DNS are configured on your router, if you suspect that someone remotely accessed it and changed it.
Hi! Thanks for the reply :)
This seems to happen on any device connected to the router. If I do it on my phone I get redirected to a different site:
The router is set to Access Point mode from another router due to the layout of the building I'm in. DNS configuration looks like this (I'm not sure if this is right or not...):
Thanks again!
Then look at your main router, as it is the one providing DNS services to your clients. The AP only bridges your clients with that main router.
Also note that the asusnetworks.com domain will only work properly if your main router is an Asus one, and is configured to handle DNS queries.
The bare a s u s n e t w o r k s . c o m domain seems to be vulnerable anyway.
The proper address should be the full: w w w . a s u s n e t w o r k s . c o m
The very best is to avoid those addresses and access the router by its IP address, by default 192.168.1.1
