Router that support Wol over internet
vestermark
I have an Airport Extreme which doesn't work with WOL over the internet (only Wake on LAN is supported), so I'm looking for a router that supports this feature.
Any suggestions?
Thanks. I've never heard of Draytek before. Can anyone recommend their routers?
I was looking at the Vigor 2710n since it has built in ADSL2 modem and n-wireless. Unfortunately it lacks gigabit ethernet.
And is wol over the internet really that uncommon a feature that none of the big manufacturers make wireless routers that support it!
I am glad it worked out for you.
I have just bought a Vigor 2800 off ebay for £35 ( $55 ).. Just got to wait for it to arrive.
The 2710n was 1100 Danish Kroner (~130£) but I think it's worth it. And when I sell my Airport Extreme and ADSL modem it's not too bad... Just too bad the 2710Vn isn't available yet, because then I could have sold my Linksys VoIP Gateway also... and would have way less cable clutter.
I just bought the Draytek 2710n. So far everything is looking great with Wake on WAN working like charm.
Glad everything is working ... for future reference I have had success with using DDWRT or Tomato firmware flashed on a router which have the same ability. YMMV
