Router threw a wobbla - "Top" info in syslog?
alan6854321
Any idea what happened here?
Router UI locked up and when I looked in the syslog (On a remote machine) it was full of weird messages including what looks like the output from a "top" command.
A reboot fixed it.
04-Apr 16:53:40 AX rc_service: skip the event: start_amas_wlcconnect.
04-Apr 16:53:40 AX rc_service: watchdog 2430:notify_rc start_amas_misc
04-Apr 16:53:40 AX rc_service: waitting "" via  ...
04-Apr 16:53:55 AX rc_service: skip the event: start_amas_misc.
04-Apr 16:53:55 AX rc_service: watchdog 2430:notify_rc start_amas_ssd
04-Apr 16:53:55 AX rc_service: waitting "" via  ...
04-Apr 16:54:10 AX rc_service: skip the event: start_amas_ssd.
04-Apr 16:54:30 AX BONDING: no report
04-Apr 16:54:40 AX BONDING: option disabled
04-Apr 16:54:40 AX top: Mem: 809800K used, 208988K free, 4636K shrd, 26488K buff, 191828K cached
04-Apr 16:54:40 AX top: CPU:  2.3% usr  0.0% sys  0.0% nic 97.6% idle  0.0% io  0.0% irq  0.0% sirq
04-Apr 16:54:40 AX top: Load average: 0.18 0.23 0.22 1/298 29628
04-Apr 16:54:40 AX top:   PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
04-Apr 16:54:40 AX top: 29626 29625 AsusAdmi R     3328  0.3   0  2.3 top -b -n 1
04-Apr 16:54:40 AX top:  2524     1 AsusAdmi S    20880  2.0   2  0.0 conn_diag
04-Apr 16:54:40 AX top:  8133     1 AsusAdmi S    20548  2.0   1  0.0 wred -B
04-Apr 16:54:40 AX top:  2552     1 AsusAdmi S    20212  1.9   2  0.0 cfg_server
04-Apr 16:54:40 AX top:  2522     1 AsusAdmi S    19496  1.9   0  0.0 roamast
04-Apr 16:54:40 AX top:  2547  2524 AsusAdmi S    18472  1.8   0  0.0 amas_portstatus
04-Apr 16:54:40 AX watchdog: start httpd
04-Apr 16:54:40 AX rc_service: watchdog 2430:notify_rc start_httpd
04-Apr 16:54:40 AX rc_service: waitting "" via  ...
04-Apr 16:54:55 AX rc_service: skip the event: start_httpd.
04-Apr 16:54:55 AX hour_monitor: value = 1(0x1)
04-Apr 16:54:55 AX rc_service: watchdog 2430:notify_rc start_amas_bhctrl
04-Apr 16:54:55 AX rc_service: waitting "" via  ...
04-Apr 16:55:10 AX rc_service: skip the event: start_amas_bhctrl.
04-Apr 16:55:10 AX rc_service: watchdog 2430:notify_rc start_amas_wlcconnect
04-Apr 16:55:10 AX rc_service: waitting "" via  ...
04-Apr 16:55:25 AX rc_service: skip the event: start_amas_wlcconnect.
04-Apr 16:55:25 AX rc_service: watchdog 2430:notify_rc start_amas_misc
04-Apr 16:55:25 AX rc_service: waitting "" via  ...
04-Apr 16:55:40 AX rc_service: skip the event: start_amas_misc.
04-Apr 16:55:40 AX rc_service: watchdog 2430:notify_rc start_amas_ssd
04-Apr 16:55:40 AX rc_service: waitting "" via  ...
04-Apr 16:55:55 AX rc_service: skip the event: start_amas_ssd.
04-Apr 16:56:22 AX rc_service: httpd 32025:notify_rc reboot
I've the same issue you have. After some weeks of uptime, this strange lines shows up for me on syslog. RT-BE86U here, Merlin 3006.102.3. It could be related to Bonding on port 1/2?
Mar 12 01:11:46 RT-TATI BONDING: option disabled
Mar 12 01:11:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 01:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 01:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 01:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 01:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
Mar 12 01:12:44 RT-TATI ddns: current ipv6_service: dhcp6 | old ipv6_service: dhcp6
Mar 12 01:12:44 RT-TATI ddns: IP address, server and hostname have not changed since the last update.
Mar 12 01:21:46 RT-TATI BONDING: successfully
Mar 12 01:41:46 RT-TATI BONDING: option disabled
Mar 12 01:41:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 01:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 01:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 01:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 01:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
Mar 12 01:51:46 RT-TATI BONDING: successfully
Mar 12 02:11:46 RT-TATI BONDING: option disabled
Mar 12 02:11:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 02:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 02:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 02:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 02:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
Mar 12 02:21:46 RT-TATI BONDING: successfully
Mar 12 02:41:46 RT-TATI BONDING: option disabled
Mar 12 02:41:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 02:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 02:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 02:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 02:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
Mar 12 02:51:46 RT-TATI BONDING: successfully
Mar 12 03:01:00 RT-TATI connmon: Trimming records entries from database...
Mar 12 03:01:00 RT-TATI connmon: Database record trimming completed successfully.
Mar 12 03:01:00 RT-TATI connmon: Running database analysis and optimization...
Mar 12 03:01:00 RT-TATI connmon: Database analysis and optimization completed successfully.
Mar 12 03:11:46 RT-TATI BONDING: option disabled
Mar 12 03:11:46 RT-TATI top: Mem: 904976K used, 112324K free, 10148K shrd, 204032K buff, 72708K cached
Mar 12 03:11:46 RT-TATI top: CPU:  2.3% usr  6.9% sys  0.0% nic 90.6% idle  0.0% io  0.0% irq  0.0% sirq
Mar 12 03:11:46 RT-TATI top: Load average: 0.26 0.39 0.34 1/290 6554
Mar 12 03:11:46 RT-TATI top:   PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
Mar 12 03:11:46 RT-TATI top:     1     0 admin    S    16148  1.5   1  5.5 /sbin/init
Mar 12 03:11:46 RT-TATI top:  5116  5086 admin    S    19268  1.8   2  1.8 amas_portstatus
Mar 12 03:11:46 RT-TATI top:  6552  6551 admin    R     3116  0.3   2  1.8 top -b -n 1
Mar 12 03:11:46 RT-TATI top: 17420 17419 admin    S     344m 34.5   2  0.0 syslog-ng
Mar 12 03:11:46 RT-TATI top:  5128     1 admin    S     114m 11.4   0  0.0 cfg_server
Mar 12 03:11:46 RT-TATI top:  5086     1 admin    S    21420  2.0   1  0.0 conn_diag
Mar 12 03:11:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 03:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 03:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 03:11:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 03:11:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
Mar 12 03:21:46 RT-TATI BONDING: successfully
Mar 12 03:41:46 RT-TATI BONDING: option disabled
Mar 12 03:41:46 RT-TATI hour_monitor: value = 1(0x1)
Mar 12 03:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_bhctrl
Mar 12 03:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_bhctrl)
Mar 12 03:41:46 RT-TATI rc_service: watchdog 4051:notify_rc start_amas_misc
Mar 12 03:41:46 RT-TATI custom_script: Running /jffs/scripts/service-event (args: start amas_misc)
