Router with VLAN capable WAN port?
Jeroen1000
Colour me stupid but does this exist? I just want the WAN port to function as an untagged member of, lets say, VLAN2.
Then, I'd create a trunk (tagged port) on a LAN port of the router, which trunks VLAN 2 and some other VLAN. Assume this trunks ends in a VLAN switch, then members of VLAN 2 on this switch will bypass NAT, firewall and routing, and essentially function as a WAN port.
Is this function so far fetched? :)
cheers,
Jeroen
I don't get what you're asking....
routers segregate LAN's. If you want to pass through all data and have the router do nothing then why have the router?
I attached a picture to make this easier to follow:)
I have a tv ip box somewhere (represented by the device with the red line, left in the picture). It is connected to a VLAN switch, which in turn is connected to another VLAN switch, which in turn is connected to the router.
So I've put this box in VLAN20. I want it to get a public IP from my ISP (I don't have a choice).
So essentially, I want a VLAN20 that behaves like it is bridged with the WAN port. Except, I want it to happen at wirespeed and bridging is done is software.
Logically, it would be as if the tv box is plugged directly into the ISP modem.
Virtually, I want to achieve this with a VLAN.
I hope I did a better job explaining this time:D
You should be able to do this as long as your router allows you to assign the DMZ to a VLAN. Router should probably also be able to put VLANs in separate subnets.
If you have multiple IP addresses from your ISP and want to assign a particular one to the device, the router will need to support one-to-one NAT, too.
I think the Cisco RV042 can do all this.
Googling for "put a VLAN in DMZ" will give you other ideas.
Good idea! I'll look into that. It would/might (this is an assumption) be possible to configure a Cisco IOS router as DDWRT does it:
http://www.dd-wrt.com/wiki/index.php/Default_Configuration_Overview
The wan port as access port in VLAN 20. The trunk port would then be in VLAN10 + 20 (obviously). And then route VLAN10 to a virtual VLAN20 interface (which holds the public IP). But Cisco's are a bit expensive considering I want good NAT throughput. So thanks Tim, I'll examine your suggestion.
ps: ever heard of MAC address passthrough? They talk about this on a forum about Belgian ISP's. Our ISP's routers would perform that trick. But I am unfamlilar with it.
