RT-AC-86U OpenVpn problems, 384.8_0
Jörgen Hyckenberg
Hi.
Trying to get the OpenVPN to work on 384.8_0 but one profile works if I add another one it just says "public ip unknown" and get no internet access. The first profile I install works, doesn't matter which one.
If I restore the GW to the original firmware (3.0.0.4.384_32799-gfe72567) everything works as it should!
I'm using Integrity Vpn and ExpressVpn
Anyone else has this problem and solved it?
Dec 9 06:06:24 ovpn-client3[1407]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Dec 9 06:06:24 ovpn-client3[1407]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Dec 9 06:06:24 ovpn-client3[1407]: TCP/UDP: Preserving recently used remote address: [AF_INET]82.103.130.13:1195
Dec 9 06:06:24 ovpn-client3[1407]: Socket Buffers: R=[524288->1048576] S=[524288->1048576]
Dec 9 06:06:24 ovpn-client3[1407]: UDP link local: (not bound)
Dec 9 06:06:24 ovpn-client3[1407]: UDP link remote: [AF_INET]82.103.130.13:1195
Dec 9 06:06:24 ovpn-client3[1407]: TLS: Initial packet from [AF_INET]82.103.130.13:1195, sid=65640a48 4e0fed39
Dec 9 06:06:24 ovpn-client3[1407]: VERIFY OK: depth=1, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=ExpressVPN CA, [email protected]
Dec 9 06:06:24 ovpn-client3[1407]: VERIFY OK: nsCertType=SERVER
Dec 9 06:06:24 ovpn-client3[1407]: VERIFY X509NAME OK: C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server-2510-5a, [email protected]
Dec 9 06:06:24 ovpn-client3[1407]: VERIFY OK: depth=0, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server-2510-5a, [email protected]
Dec 9 06:06:24 ovpn-client3[1407]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Dec 9 06:06:24 ovpn-client3[1407]: [Server-2510-5a] Peer Connection Initiated with [AF_INET]82.103.130.13:1195
Dec 9 06:06:25 ovpn-client3[1407]: SENT CONTROL [Server-2510-5a]: 'PUSH_REQUEST' (status=1)
Dec 9 06:06:25 ovpn-client3[1407]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.198.0.1,route 10.198.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.198.0.154 10.198.0.153,peer-id 32,cipher AES-256-GCM'
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: timers and/or timeouts modified
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: --ifconfig/up options modified
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: route options modified
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: peer-id set
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: adjusting link_mtu to 1629
Dec 9 06:06:25 ovpn-client3[1407]: OPTIONS IMPORT: data channel crypto options modified
Dec 9 06:06:25 ovpn-client3[1407]: Data Channel: using negotiated cipher 'AES-256-GCM'
Dec 9 06:06:25 ovpn-client3[1407]: NCP: overriding user-set keysize with default
Dec 9 06:06:25 ovpn-client3[1407]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 9 06:06:25 ovpn-client3[1407]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 9 06:06:25 ovpn-client3[1407]: Preserving previous TUN/TAP instance: tun13
Dec 9 06:06:25 ovpn-client3[1407]: NOTE: Pulled options changed on restart, will need to close and reopen TUN/TAP device.
Dec 9 06:06:25 ovpn-client3[1407]: vpnrouting.sh tun13 1500 1557 10.198.0.130 10.198.0.129 init
Dec 9 06:06:25 openvpn-routing: Configuring policy rules for client 3
Dec 9 06:06:25 ovpn-client3[1407]: /bin/ip route del 10.198.0.1/32
Dec 9 06:06:25 ovpn-client3[1407]: /bin/ip route del 82.103.130.13/32
Dec 9 06:06:25 ovpn-client3[1407]: /bin/ip route del 0.0.0.0/1
Dec 9 06:06:25 ovpn-client3[1407]: /bin/ip route del 128.0.0.0/1
Dec 9 06:06:25 ovpn-client3[1407]: Closing TUN/TAP interface
Dec 9 06:06:25 ovpn-client3[1407]: /bin/ip addr del dev tun13 local 10.198.0.130 peer 10.198.0.129
Dec 9 06:06:25 ovpn-client3[1407]: updown.sh tun13 1500 1557 10.198.0.130 10.198.0.129 init
Dec 9 06:06:25 rc_service: service 1673:notify_rc updateresolv
Dec 9 06:06:26 ovpn-client3[1407]: TUN/TAP device tun13 opened
Dec 9 06:06:26 ovpn-client3[1407]: TUN/TAP TX queue length set to 100
Dec 9 06:06:26 ovpn-client3[1407]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Dec 9 06:06:26 ovpn-client3[1407]: /bin/ip link set dev tun13 up mtu 1500
Dec 9 06:06:26 ovpn-client3[1407]: /bin/ip addr add dev tun13 local 10.198.0.154 peer 10.198.0.153
Dec 9 06:06:26 ovpn-client3[1407]: updown.sh tun13 1500 1557 10.198.0.154 10.198.0.153 init
Dec 9 06:06:26 rc_service: service 1735:notify_rc updateresolv
Dec 9 06:06:28 ovpn-client3[1407]: /bin/ip route add 82.103.130.13/32 via 100.70.92.1
Dec 9 06:06:28 ovpn-client3[1407]: /bin/ip route add 0.0.0.0/1 via 10.198.0.153
Dec 9 06:06:28 ovpn-client3[1407]: /bin/ip route add 128.0.0.0/1 via 10.198.0.153
Dec 9 06:06:28 ovpn-client3[1407]: /bin/ip route add 10.198.0.1/32 via 10.198.0.153
Dec 9 06:06:28 ovpn-client3[1407]: Initialization Sequence Completed
Hi.
Try 384.8_2
Hi.
Try factory reset as well. Going back and forth between stock and merlin begs the need for it.
