RT-AC1900P flow acceleration?
wallaby32
Maybe I missed this in the change logs or something IDK, but, i'm using the new best buy AC1900p router with merlin 380.61 (AC68U version) and I'm trying to figure out if this router has flow acceleration, or was it disabled since 380.58?
I do have CTF enabled, so maybe they are one in the same now, i'm unsure?
any clarification will be greatly appreciated.
There is a reason that the newer models (3100/88U/5300) only do CTF and not FA but I can't remember what it is. The answer is on this site somewhere. Given that the 1900P uses some newer hardware than the 68U that may be why it doesn't do FA. I'm able to get 945 Mbps WAN-LAN on my 68U Rev B1 with only CTF enabled so I don't even bother with FA. I also like to monitor my bandwidth usage with Traffic Monitor and with FA enabled it does not correctly measure the usage.
