RT-AC3200 380.65 openvpn problem
Coipu
Hi, sorry to trouble you clever people.
I used to have openvpn client set up for my Torguard on policy routing with a media center and NAS added to list using vpn and everything else just automatically got normal wan. worked flawlessly for ages.
Now updated to 380.65 and if I enable openvpn client all wifi clients can still connect but lose internet access.
any advice for me greatly appreciated would try to show log but forum stops me??
Edit, wiping and downgrading hasnt solved the problem either...
Further info: problem only exits when routing is set to policy rules (regardless if i give wireless client fixed address and specify vpn or wan to it). I also tried to use my old rt-ac68u which was on 380.64_2 and it did the same thing so I'm not sure where problem lies now at all.
Solved, Torguard are going to help me with settings as another vpn provider works fine, meaning problem doesnt lie with router at all. sorry for the time I just stole from you.
