RT-AC3200 dead WAN port
hayseed
hello,, newbie here -- I have a RT-AC3200 with a dead WAN port (wifi radios seems to work fine) - is there a way to use one of the other lan ports as the wan interface. Not sure I can find the receipt to rma return so thought I would try here first ... also if its possible if someone can provide the command set to remap these -- i can figure out some things but this area i may need some help -- thanks and have a good 4th !
Yes you can use the fall over wan option or whatever it is called. It lets you assign one of the other lan ports to work as the wan.
I will see if I can give that a try,,,, not what I was expecting for a solution but may be easier than what I was thinking originally -- thanks
there is a Dual Wan Tab that you can either enable for fail over and pick an alternate source or you can just change the primary WAN port to what ever lan port exist ,, it works 00 now I will try to call asus and see if they will repair it .. thanks for you help
