RT-AC5300 : combine two Internet connections ?
kishork
i have two 50 mbps Internet connections configured in dual wan fail over mode.. it is working as expected in fail over mode..
is there any way i can combine these two connections and get one pipe of 100 mbps ? any kind of hardware which can take these two as input and output of that i can connect to this router ? possible ?
Sent from my SM-A800I using Tapatalk
That depends of what kind of internet feeds you have. You can already do load balancing instead of fail-over if you wanted to. That would give you an aggregated connection of up to 100Mbps. But to have a true 100Mbps connection you would have to "bond" both the internet feeds together. This can be done but usually requires that both feeds are provided by the same company and that they support such a configuration.
