RT-AC5300 Static WAN IP Problems
RukusDM
I have Greenlight Networks Fiber connection. It has been working fine for nearly a year. I needed to goto a static ip on the WAN side and they provided that with the associated connection information. The Greenlight Side uses a NOKIA fiber to Ethernet box which gets plugged into my router.
I have yet in 2 tries now to get static WAN to work. The first time i had to go back to Dynamic so the wife and i could work.
The problem is that the Router shows a Red Light on the front indicating there is no WAN connection. When you go into the Web browser for the setup it shows Disconnected, not cable unplugged.
I've rebooted it,rebooted the fiber box re flashed memory in router, with no success. When i converted back to dynamic, i had the same issue earlier this week. Had a lot of messing around then it decided to get a connection.
The confusing thing is if i put these numbers into my computer and plug the computer into the fiber box i have no issue as im in that mode now typing this.
Does anyone have any idea what the hell could be wrong LOL. I've attached a picture of the WAN setup page. Thanks in advance
Problem is fixed. The last octet of the subnet mask was .128 Turns out they sent me a new email and the octet should have been 129
I have no clue why that subnet mask worked with my computer and not my router. Definitely strange
Your screenshot shows it was the gateway that had 128, not the subnet mask. So you were using the wrong gateway?
