If they give you a /64 prefix the modem cannot delegate prefixes to a router, a /56 prefix is quite normal so the modem can delegate 255 other prefixes to requesting routers.
Incorrect. WRONG WRONG WRONG. I have a /64 from TWC on my RT-AC87U. the modem is in bridge mode so it doesn't even pick up an iov4 or 6.. It acts like an old fashioned frame relay modem. ALL the routers requests are sent DIRECTLY to your ISP. ANY asus router (from the 56u and up) with proper firmware can delegate ANY /PREFIX.
/64 gives out IPs fine BUT YOU MUST TURN ON DCHPV6 even in stateless mode and even with dchp-pd. In my case I don't use any dchp or dns on my router. My connection is so fast it overloads it even it CT+AF mode. It takes newer 400-600 asudnrouters to fully support 1Gb/sec connection. I'm at 350x25 and even bypassing the cpu using hw acceleration, the unit heats up and crashes 1-2X/day. IPv6 doesn't need Nat... So it doesn't need to use the cpu for or hw accell.. The more sites that use IPv6, the cooler my unit runs over time. I'm probably overdue for a FW update too. I'd go 100% IPv6 but then I couldn't connect to 1/2 the websites out there.
Typical IPv6 prefix assignments:
– Service provider (LIR): /32, 2^32/64 subnets.
– Large end user: /48, 65535/64 subnets - absurd for the home or small-mend business
– Medium end user: /56, 256/64 subnets - not needed for consumers.
– Small/ Home/ SOHO: /64 or /60 1 or 16 /64 subnets
The asus router can use all of those, but /64 is best. 1, /64 subnet. /56 is far more complex 256 /64 subnets and the asus can only do ONE. you'd need other servers and or routers for more subnets. But it still can do ONE /56 or ONE /48, /32, ETC
Good news for iPad / iPhone / OS X users... ANY app put on the App Store must fully support IPv6 and if it's a client server app, and servers are IPv4, it's up to them to do the 6 to 4 conversion. Apple gave existing apps until 2017 to b fully IPv6 compatible. Ios9 defaults to IPv6, if available then falls back to IPv4. Same with OS X and windows. Microsoft issued a similar mandate. Unsure about android.
Why ppl think a /64 won't work is BEYOND ME. RFC4294 suggestS ALL CONSUMER PREFIXES BE /64 for now
http://www.txv6tf.org/wp-content/uploads/2012/09/Doyle-IPv6-Address-Design.pdf
It's a few yrs old but very valid. BUT AS LONG AS U GET A PREFIX WITH ANY /XX, the asus router WILL DELEGATE. AND UT STATELESS IT DIESNT HAVE TO. router advertises the prefix and /xx and clients take it from there. If no stateless dhcpv6 , clients assume the gateway and dns are one in the same. '
If unwanted more control , use state full to list a range within the prefix and specific Dns servers to pass to clients
You can also go stateless with no dvhpv6 and no router advertisement. You get the prefix off your router and set up, for example a stateless dchpv6 server with router advertisement on a win 2008 or 2012 server. This is far more complex. The win server will tell clients the stateless info they need to auto configure but will give them other settings, if configured, name servers (dns), gateway, and a bunch of other options the asud can't do. Or u can go state full assign a scope with dchpv6 reservations ...but if your ISPs changes your prefix.. You have work to do.
My 64bit 2008r2 server runs under oracle virtual box on my PCs and only needs 1GB ram and 2 virtualized CPUs. I have 32GB so it's not missed. Even 16 would b fine.
IPv6 gives 2 to the 128th power addresses vs 4.3B IPv4 addresses
OR
340,000,000,000,000,000,000,000,000,000,000,000,000 IPV6 addresses
or simply 340 undecillion IPv6s or ... 340 trillion septillion.... 340 million nonillion That's not running out. Even if we had 10billion people and each had 10 devices between home and work...that's 100B IP 6 needed. Even if each 10B used 1000 IPv6 addresses , that's 10 trillion IPv6 needed. Not counting isp routers , etc. 10 trillion is only 10,000,000,000,000 compared to a pool of 340,000,000,000,000,000,000,000,000,000,000,000,000. That wouldn't run out even 500 yrs. . MAYBE LONGER.
anyway the most COMMON IPv6 assigned by a native IPv6 connection is /64 with /56 coming in second. Your router should handle ANY PREFIX. I set mine to 2001::/128 and I got IPv6 addresses but non routable lol.
You can also do STATIC once u have a prefix as it RARELY will change. For /64, some devices are static and I just do prefix::1,2,3,4,5 etc. That gives them nice neat addresses. But in stateless mode a device gets many IPv6:
Primary
Temporary (can be 1-3)
Link local
In stateless mode, you can set primary to prefix::10 but
Some will go huh? STATIC without a full dchp, there will be conflicts. Nope. 1) u get too many IPs. 2) in IPv6 if a client is static , no other client will auto configure that IPv6
MAKE SURE TO TURN ON DCHPV6 FIREWALL! these are public ip addresses NOT hidden behind a NAT. ANY MAC or PC should have firewalls also.
The says stateless dvhpv6 just supplies the "other" info like DNS servers and gateway to clients. In state full mode it does more. But no reservations allowed. Use static on clients for that.
I'm running in
native mode
Dchp-pd
Router advertisement on
Operation Mode:
Wireless router Firmware:
378.55 (Merlin)
IPv6
Configure the IPv6 Internet setting of RT-AC87U.
Connection type Native
DHCP-PD Enable
IPv6 LAN Setting
LAN IPv6 Address
2606:a000:121d:405f::1
LAN Prefix Length
64
LAN IPv6 Prefix
Auto Configuration Stateless
Lease time 86400
IPv6 DNS Setting
(.....405f::2 is my windows 2008 R2 server. It does dchpv4, dnsv4&6, it also has a stateless dhcpv6 server that lets stateless clients get other and more info than the router could ever give. It also registers clients with the Dns server for forward and reverse lookups) but what I do is OPTIONAL.
Connect to DNS Server automatically Disable (I do not want to use my ISPs dns)
IPv6 DNS Server 1
IPv6 DNS Server 2
IPv6 DNS Server 3
... 2606:a000:121d:405f::2, 2001:4860:4860::8888, 2001:4860:4860::8844 (this puts the router in dons forward mode. And dons queries sent to it go to my server. If that fails, Google. But this is redundant as the "other" setting flag of a stateless dhcpv6 server assigns then to clients. It's just here in case my dns goes down)
Auto Configuration Setting
Enable Router Advertisement
Enable DHCPv6 Server
Lastly, you can have the router do only IPv6 and have a separate dchpv4/dnsv4 in your house/business. And most professional dns4 will do 6 also
