RT-AC66U B1 Firmware version 3.0.0.4.384.20308 Bug fix
bbunge
Part of the Furniture
Version 3.0.0.4.384.20308 2018/02/0142.5 MBytesASUS RT-AC66U B1 Firmware version 3.0.0.4.384.20308
Bug fix
- Fixed GUI error on firmware update page.
The progress bar may always appear on firmware upgrade page after installed 3.0.0.4.384.20287.
If your router had this issue, you can manually reboot the router to solve this issue and enter the firmware upgrade page to install the latest firmware. Riden of NCC Group)
Note: I found this under Other on the Asus Firmware page
Also, I recommend a power cycle after upgrade. My bandwidth monitor did not work at first but a power cycle fixed that!
Hopefully that means other models will get the fix soon too.
I have the 88u brother and its not in there yet.:D For some reason they put it in first under other before they populate the other OS's and since this firmware gives a false positive to a new firmware update I can't depend on that either.
At least the smart phone app stayed working and returned no firmware available when the web gui was malfunctioning. I might just try using that for the upgrade just to be different otherwise I'll download the new file and upload it manually.
I just upgraded my RT-AC1900P via the GUI and everything went smoothly.
Thanks for the update!
