Hello All!
Just got this router today, installation was a flash loving it so far Except.... I am attempting to hook up my WD my book studio 2TB drive to my RT-AC66U. I do run a mac.. and it is not mounting the drive. It is recognized (unmounted) but the config untility also says usb is disabled (icon/light is on) .. I put in a 8gb sandisk thumb drive just to see what happens and it picks it up no problem and works fine. Im noticing in the log that it is saying sda unknown partition table? The WD drive is formatted for NTFS.. Any help would be much appreciated..
kernel: scsi 0:0:0:0: Direct-Access WD My Book 111D 1020 PQ: 0 ANSI: 4
Dec 31 19:00:13 dnsmasq[506]: started, version 2.65 cachesize 1500
Dec 31 19:00:13 dnsmasq[506]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Dec 31 19:00:13 dnsmasq[506]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 19:00:13 dnsmasq[506]: read /etc/hosts - 5 addresses
Dec 31 19:00:13 RT-AC66U: start httpd
Dec 31 19:00:13 crond[509]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 19:00:20 kernel: sd 0:0:0:0: [sda] 3906963456 512-byte hardware sectors (2000365 MB)
Dec 31 19:00:20 kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 31 19:00:20 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 31 19:00:20 kernel: sda: unknown partition table
Dec 31 19:00:20 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 31 19:00:20 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 31 19:00:20 kernel: scsi 0:0:0:1: Enclosure WD SES Device 1020 PQ: 0 ANSI: 4
Dec 31 19:00:20 kernel: scsi 0:0:0:1: Attached scsi generic sg1 type 13
Dec 31 19:00:20 hotplug[549]: USB /dev/sda(unknown) failed to mount at the first try!
