RT-AC66U VPN
boowho
Has anybody successfully gotten this router to work with any VPN provider; e.g. ExpressVPN, etc??
I've tried four different services using OpenVPN and so far no luck. All of 'em use chat for support and I always seem to get a rep with no experience at all.
I'm running Merlin FW in the router, FWIW.
Boowho??
Is it an AC66 or AC66_B1? What specific version of Merlin are you running? What have you tried and what errors do you get? The router syslog will usually tell you what's wrong from an OpenVPN perspective. You can post those messages and someone might see your problem right away.
It's a plain 66 not 66B1 Merlin version 380.70. Right now on expressVPN I can't find the OpenVPN login credentials (from ExpressVPN) to put into the router.
