RT-AC68U, 3.0.0.4.380_3264
Bit of a newb question... Today I bought an RT-AC68U to use in bridge mode. The plan was to wire up my PCs etc to the RT-AC68U, and put it into bridge mode over 5Ghz to connect to the router/modem that came from the ISP.
I had read the user manual before purchasing and it seemed like it would be simple enough, but when I read the instructions on the Wireless bridge settings page it became obvious this wouldn't work - turns out the ISP router/modem doesn't support bridge mode.
So I now need another router/AP that supports WDS. I might get another RT-AC68 for simplicity/compatibility though they are relatively expensive, so will look into cheaper alternatives as 2 routers is more than I wanted to spend. A $15 ethernet cable might have been worth the hassle after all. I've got the RT-AC68 hooked up to my ISP router modem, which now has its wifi disabled, and have got internet access ok. I've wired from the RT-AC68's WAN port to one of the ethernet ports on the ISP router and no further setup was necessary- the RT-AC68 had a conflict and auto changed its IP address. Its working but is there other config settings I should change with this setup to optimize?
Anyway, to my question - It isn't clear from the instructions, but if I configure the RT-AC68 that is in the remote location as 5Ghz WDS only and 2.4Ghz Access Point, do I also set the base RT-AC68 to 5Ghz WDS only and 2.4Ghz AP? I guess I'll also experiment with the Hybrid mode, can you choose Hybrid on one side but not the other? And are there any other similar models from other manufacturers that would work well as an alternative?
I see there's a firmware update for Mesh Mode which might prove useful but I want to stick with tried and tested WDS for now. thanks
