RT-AC68 igmpproxy not work on dual-wan
Vint
Good day!
Two provider suited to the router (dual-wan). Simultaneously works all
except the TV .
Firmware on the router Merlin RT-AC68U_3.0.0.4_374.42_2.
Ran tcpdump for igmp. Detected when connected to one wire (PPPoE) multicast
pours through the desired interface (vlan2): http://funkyimg.com/view/HzzU
But when I connect a second wire (L2TP), the route is changed to : phyint vlan3
upstream ( this is the LAN interface of the second provider) . And route
changes automatically ! And accordingly multicast disappears : http://funkyimg.com/view/HzAB
Edit the file / tmp / igmpproxy.conf hands gives no result , tcpdump
shows igmp requests not to the correct interface (vlan3).
We can restore multicast by reloading the router with one wire (PPPoE).
Please help resolve this bug ! As can be strictly defined in this
devayse route igmpproxy? Or , as a second option, you can deselect
MULTICAST interface with vlan3?
P.S. On the native firmware ASUS - vlc does not work at all.
Thanks in advance for your reply!
Today came the reply from the Support ASUS, which will prepare a firmware update that fixes this problem.
Have to wait ...
What ideas until Asus silent?
Merlin, my friend, the only hope for you! Only you igmpproxy added to the source code of the original firmware!
I have no way of testing or debugging this, so no, a fix will certainly not come from me.
