RT-AC68U - 380.58 log errors
stambeccuccio
At the boot I have the following errors:
Aug 1 02:00:16 kernel: pflash: found no supported devices
Aug 1 02:00:16 kernel: bcmsflash: found no supported devices
Aug 1 02:00:31 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:31 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:34 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Aug 1 02:00:34 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
What is this?
Thank You
All those messages are perfectly normal. The Linux kernel loves to try to load a bunch of hardware driver or to enable some hardware-specific feature, and fail with a log entry if there is no compatible hardware found on the system. And it simply moves on to the next driver then.
