RT-AC68U 384.13 Manual Port Forwarding vanishing
Vager
Hi.
Hoping to get some help.
I just recently upgraded to 384.13 and everything worked fine except for all of my manual port forwarding I had set up. They were all gone. So I manually re-added all of them.
Now I can't seem to recall, but on that page at the bottom, there's no "Apply" button after you are done. However I don't know if it was there before.
After that all was working, however for reasons I can't seem to figure out they keep on getting removed.
I had about 9 entries originally. I've tried from only entering 3, but nothing seems to stick. The amount of time before it vanishes seem to be random as well.
Has anyone seen this before?
There is no apply button anymore. They take affect immediately. Check if you are running out of nvram space on Tools page.
If so, run this command to see the largest consumers of nvram space:
nvram show | awk '{print length(), $0 | "sort -n -r"}' | cut -d"=" -f 1 | head -n 20
Ok I will take a look.
Here's what I see for NVRAM usage.
NVRAM usage 65520 / 65536 bytes
I guess this is close to the limit.
Question, where do I enter in that command above to check the usage.
Yes, that's full. The command is meant to be entered in an SSH terminal logged into the router IP address using a program like PuTTY for Windows, or even built-in ssh commands in Windows 10 or MacOS. You'd need to enable SSH on the Administration - System page in the GUI first.
Ok thanks.. figured it out.
3071 custom_clientlist
1089 sshd_hostkey
1038 wrs_rulelist
810 nc_setting_conf
635 dhcp_hostnames
624 sshd_dsskey
619 dhcp_staticlist
519 dnsfilter_rulelist
512 rc_support
450 wrs_app_rulelist
338 sshd_ecdsakey
299 vpn_client_custom2
298 vpn_client1_cust2
297 vpn_client_cust2
188 sr_rulelist
170 lan_route
167 MULTIFILTER_MACFILTER_DAYTIME
164 MULTIFILTER_DEVICENAME
159 MULTIFILTER_MAC
153 asus_device_list
How can I remove the VPN client stuff.. I was using that in the past.. but not anymore.
I think you can go into the VPN client settings and hit the Default button at the bottom to reset them and hopefully shrink them.
Thanks so much for your help on this.
Here's where I am now. I still have "299 vpn_client_custom2" in which didn't get removed when I applied default to the VPN client.
I also abbreviated the hostnames for my devices and removed some other things here and there. Hopefully this should now be enough room in the NVRAM.
If you can suggest how to remove the vpn_client custom, that can free up a little more.
size: 64095 bytes (1441 left)
2791 custom_clientlist
1089 sshd_hostkey
1038 wrs_rulelist
810 nc_setting_conf
624 sshd_dsskey
512 rc_support
397 dhcp_hostnames
395 dhcp_staticlist
338 sshd_ecdsakey
188 sr_rulelist
170 lan_route
159 MULTIFILTER_MAC
131 wl1_chansps
129 wps_env_buf
