Rt-ac68u B2 dd-wrt
Pierino
Just wanted to let anyone know that I provided the appropriate info to BrainSlayer at dd-wrt a couple weeks ago and this variant is now supported.
I flashed it two days ago using tftpd32 after putting it into recovery mode.
After it flashed, it seemed to be in a boot-loop.
I used the wps for a reset and it booted up.
I then flashed the latest Kong build on it.
It has been running fine for my use for two days.
Until it's mainstreamed - it's going to be a "beta"... Not a bad thing - the Linksys WRT's were beta for a long time with Kong's private builds...
All of the dd-wrt are beta. Kong no longer supports the wrt’s.
All of the dd-wrt beta. Kong no longer supports the wrt’s.
And I understand why - the Linksys WRT's are a bit painful...
Great HW, stuck with software due to 'issues'... disable WiFI, and OpenWRT is pretty awesome - Marvell was good with kernel and bootloader support there, it was always the wireless side with FOSS vs. Closed Source drivers...
Kong with DD-WRT - did the best with what he had...
