RT-AC68U CPU Temp
  • Thread starter Thread starter Deleted member 22229
  • Start date Start date
D
Guest
Got a bran new AC68U the router as of now is working great, using the latest Merlin build 39_0. Looking in the UI i see the CPU temp is 78C is this in spec ? The radio temps are normal 2G- 51C, 5G- 53C
This is normal for the CPU as its designed to run at high temperatures as discussed previously. If you want to lower this for whatever reason, consider using usb fans next to the router to maximize airflow.
temp high
Hello
Is normal this temperature?
I have conection over ppoe and vpn pptp.
CPU Temp is 90?!
