[RT-AC68U] I can´t upgrade to 380.68_4
PsychoDad
Hi, I´m using 380.68_2 on my RT-AC68U. If I try to update , I receive this message :
Invalid Firmware Upload
Firmware upgrade unsuccessful. This might result from incorrect image or error transmission, please check the model name RT-AC68U and version of firmware from support site and try again.
I downloaded a couple of times, Factory reset and Nothing.
Can you help me ?
The image clearly shows you are downloading firmware for a model that is NOT an RT-AC68U.
It starts with RT-AC8.., not RT-AC6...
I tried to downgrade to 380.68 . Same problem. I think that file is corrupted.
P.S. SHA OK
Thanks! I think the file inside zip was wrong.
Downloaded again, and the file was right now (I downloaded 5 times before).
