RT-AC68U Reboots Randomly - Bad Eraseblock?
Bad blocks are fairly common with this NAND type, nothing abnormal there. That's why the flash has a badblock table to map these out.
All your log indicates is your router was rebooted.
You're both right and I've checked the longer log for the whole day and don't know why it randomly reboots. This has happened two previous times like 1-2 weeks between each occurance. There were no "signs" leading up to the reboot. It just happens during normal use. It's connected to a power strip that also powers our ATT Gateway and Fiber box and neither of those rebooted or had any issues.
What do I do? Since I haven't been able to narrow down the issue through the log files should I try a full reset and firmware update? I believe there are several ways to go about this...
That's never a bad option. May help, may not, but at least you know it will be "clean" starting point to potentially troubleshoot further.
I would disable firewall logging. This puts an unnecessary strain on your router.
