RT-AC68U
How do I assign a LAN port 4 to a different VLan so that it will get a different IP address from 192.168.4.1 subnet automatically?
This is what I see when I go into the CLI of my router:
admin1@RT-AC68U-6140:/jffs/configs# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:17:10:98:1c:09
Port 1: 100FD enabled stp: none vlan: 1 jumbo: off mac: 00:15:99:6f:cd:d7
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: c8:0a:a9:0a:b0:92
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 20:cf:30:e3:3e:26
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 3c:97:0e:84:db:fd
Port 5: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 88:d7:f6:af:61:40
Port 7: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 4 5t
2: vlan2: 0 5
1045: vlan1045: 2 8u
1046: vlan1046: 2 7t
1047: vlan1047: 0t 3t 8u
1099: vlan1099: 1t
1100: vlan1100: 0t 1 2t 3t 4
1101: vlan1101: 0 1
1102: vlan1102: 0t 4t 7t
1103: vlan1103: 1 5 7t
ASUSWRT-Merlin RT-AC68U 384.18_0 Sun Jun 28 17:57:07 UTC 2020
admin1@RT-AC68U-6140:/tmp/home/root# cd /jffs/configs
admin1@RT-AC68U-6140:/jffs/configs# ls
admin1@RT-AC68U-6140:/jffs/configs# sudo ls
-sh: sudo: not found
admin1@RT-AC68U-6140:/jffs/configs# vi dnsmasq.conf
admin1@RT-AC68U-6140:/jffs/configs# vi /jffs/configs/dnsmasq.conf
How do I configure my router on LAN port 4 to use a different DHCP server on a different VLAN?
I don't know the specific commands because I've never need to to do it. But there are already numerous posts about this, including examples. Search the forum.
Does anyone know how to put LAN port 4 into a different VLan as right now all LAN ports are on Vlan1 by default on a Asus RT-AC68U merlin router?
@ColinTaylor
Currently on my Asus RT-AC68U merlin router, the default settings are being used and when I look at the VLan configurations, VLAN1 is where all lan ports are and VLAN2 is the WAN port. How do I create different subnets for each lan port after I created the VLAN 103?
Sorry, I don't know as it's not something I've ever wanted to do. As I said previously, there are numerous posts that already cover this so I suggest that you search for those.
I tried looking for some clear instructions on how to accomplish this on the forum but I didn't seem to find anything. The only thing I found was how to create a VLan but not assigning a physical port
