I had so much trouble adding aimesh node. I have 4 routers. RT-AC3100, TM-AC1900 (Convert to RT-AC68U), RT-AC68P, RC-AC68W. I was able to config AC3100 as main, and AC68U and AC68P as nodes.
AC68U connected right away, AC68P took me a couple for resets and different firmwares, but I got both of them working eventually.
When I tried to connect RT-AC68W, thats when the headache starts.
First, after I finishing config RT-AC68W using LAN cable, and connect back to AC3100. This winodw pop out and disappear in 3 second.
I tried all the firmware on asus website, and reset (using button and through software) + clear nvram (using WPS) + 30 + 30 + 30 more than dozen times. I even reset my AC3100 to default, and also tried Asus Android app.
I came across an article online saying RT-AC68U is pretty much same as RT-AC68W, I can tried flash CFE to RT-AC68U and use AC68U firmware.
So export the "original_cfe.bin" file, and upload the this site (cfeditor.pipeline.sh) and choose 1.0.2.0 US Aimesh.
Then upload new_cfe.bin & mtd-write & FW_RT_AC68U_30043763626.trx .
I used AC68U firmware because I had flashed AC68U firmware on AC68W router before.
Then I did a NVRAM Reset.
However, after that only USB 2.0 light comes up (without attached to any device). If I plug in a LAN cable, the LAN port will light up. I read elsewhere this means the router is bricked.
I read on this post, the guy was able to bring the router back alive using the serial cable. I just bought the cable.
Just wonder what is the odds for this to work? Or would it even work at all?
https://www.snbforums.com/threads/t...d-while-flashing-from-tomato-to-merlin.29077/
