RT-AC86U adguard question
garny68
ok so i got an RT-AC86U yesterday and as im setting it up im sure i saw a toggle switch to turn on adguard.. anyway i updated firmware to 3.0.0.4.386_41634 and today o thought id have a play with the adguard but i cant find it anywhere . has it been removed in latest firmware ?
There is no 'adguard' in stock firmware, Asuswrt. I believe ad blocking scripts(?) are available for other firmware, Asuswrt-Merlin.
There is Instant Guard for VPN use in Asuswrt.
OE
Adguard are DNS server options in WAN/DNS Server 1 and 2. Nothing to configure. Just disable Connect to DNS Server Automatically
What does Adguard mean/do then?
OE
So, for OP to use AdGuard in Asuswrt, they should disable WAN\Internet Connection\WAN DNS Setting\Connect to DNS Server automatically, and install the AdGuard DNS server settings(?):
Setup guide | AdGuard Knowledgebase
OE
Nothing to install. Those upstream resolvers are hard coded into newer Asus firmware. Select them for DNS Server 1 and 2 and done.
Edit: If you use IPV6 you will have to enter the DNS IPV6 servers manually. See: https://adguard.com/en/adguard-dns/overview.html#instruction
