RT-AC86U f/w 3.0.0.4.384_20648 and ShieldsUp!
OzarkEdge
Part of the Furniture
If you have installed the current firmware 3.0.0.4.384_20648 on your RT-AC86U and have not cycled power yet and are familiar with using GRC's ShieldsUp! to scan service ports, try ShieldsUp! now to see if your ports are Stealth but FAILED i.e. still probing :confused:. Mine were until I cycled power on the router (I also disabled AiProtection before power OFF, but re-enabled afterward once ShieldsUp! was satisfied... I tried many things including GUI reboot before cycling power fixed it, whatever it was). Weird.
OE
OE
Test results were as expected and did not power cycle the router. Did a restore to factory and reconfigure on the safe side. Not seeing what you had reported.
@arthurlien 384_20648 on the AC86U seems to be looking good. Appreciate the work the firmware team had put into this release, and its probably a lot seeing how clean things are at this point.
