Namrustler
My attempt to upgrade the firmware on my RT-AC86U from 384.19 to 386.1 went badly.
The current state of it is:
Does anyone have some ideas for me to try?
Thanks.
- I can access it's web server (finally).
- LAN 4 LED is the only working light.
- I can no longer enter rescue mode. I've tried the usual sequence to enter this mode, but the power LED never lights up and I've held the reset button for up to 60 seconds.
- The LED switch has no effect
- I cannot upgrade the firmware. I've tried 386.1, 384.19 and the last two official ASUS firmware and each fails with "Firmware upgrade unsuccessful. This may result from incorrect image or transmission".
- The wireless is not working. The radios are enabled but the wireless icon on the main page is dimmed, and the wireless button on the side has no effect.
- A factory reset from within the GUI works but it doesn't eliminate and of the problems I've noted above.
Thanks.
