heyrobscott
I've currently got an RT-AC66U loaded with the latest Merlin using almost all default settings and no special features (no VPN, no QoS, etc).
I'm having significant issue with stability and range on the router, specifically on my iPhone X. When I roam around the house, I often lose internet connectivity for minutes at a time. For some reason I can connect to the router admin page during this time, but I'll have to either wait or cycle wifi to get internet back. Range is fine because once I'm stationary, it usually works fine, but with occasionally drop in and out with same issue even when not moving.
I've tried setting 2.4 and 5g to both separate and identical SSID names, with no differences. 2.4 is Auto and 20mhz, 5g is AC mixed and 20/40/80mhz, both WPA2 AES.
Will upgrading to RT-AC86U help with the stability issues? Or is there something else at play here?
Also, RT-AC86U is the new hotness for ASUS and Merlin, right? I don't need 3 radios, 2 should work just fine.
Thoughts? Thanks for help!
