RT-ac87u, random reboots
Michael Jensen
Hi guys. Cant really figure this one out. Seems like its a known issue, but any fix..?
Once a day my new 87u reboots, and its driving me nuts!
Running with latest original Asus firmware. Also tried Merlins build, all the same.
Faulty device or?
Did you do factory reset after firmware update/change and reconfigured manually (or used John's NVRAM save/restore utility)?
Do you run AICloud or other applications on the router? If yes, could be memory shortage - need to add a swap file!
Faulty device or?
Could be the case as I read about others having issues with the AC87U - mine runs fine since a few weeks now - will see if it's long term stable... :rolleyes:
Well, my WAN IP changed once again! Can someone see something from this log?
Uptime is still 2 days??
Very basic setup, 1 port forward, DMZ enabled, 2.4 and 5 Ghz wifi enabled. AiCloud disabled now.
Started actually by flashing Merlin, factory reset and now on ASUS firmware. Which is preferred? ASUS or Merlin??
Hmmm..... Could the problem be dropping WAN connection instead of random reboots??
Feb 5 22:03:52 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 5 22:03:53 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 05 Feb 2016 22:03:52 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Feb 5 22:03:53 ddns update: retval= 0, ddns_return_code (,200)
Feb 5 22:03:53 ddns update: asusddns_update: 0
Feb 5 22:03:53 ddns: ddns update ok
Feb 5 22:03:53 kernel: klogd: exiting
Feb 5 22:03:53 syslogd exiting
Feb 5 22:03:54 syslogd started: BusyBox v1.17.4
Feb 5 22:03:54 kernel: klogd started: BusyBox v1.17.4 (2015-12-22 15:07:06 CST)
Feb 5 22:03:54 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 5 22:03:55 RT-AC87U: start httpd
Feb 5 22:03:55 RT-AC87U: start httpd - SSL
Feb 5 22:03:55 hour monitor: daemon is starting
Feb 5 22:04:55 rc_service: httpd 2113:notify_rc start_webs_update
Feb 5 22:43:06 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Feb 5 22:43:06 kernel: sizeof forward param = 160
Feb 5 22:43:33 kernel: Stop the IPS/AppID engine...
Feb 5 22:43:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 5 22:43:38 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Feb 5 22:43:39 kernel: sizeof forward param = 160
Feb 5 22:43:56 kernel: Stop the IPS/AppID engine...
Feb 5 22:43:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 6 03:54:09 WAN Connection: Ethernet link up.
Feb 6 03:54:09 rc_service: wanduck 405:notify_rc restart_wan_if 0
Feb 6 03:54:09 kernel: Attempt to kill tasklet from interrupt
Feb 6 03:54:10 wan: [wan0_hwaddr] == [1C:B7:2C:C2:36:F0]
Feb 6 03:54:11 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 6 03:54:12 wan: finish adding multi routes
Feb 6 03:54:12 rc_service: udhcpc 2582:notify_rc stop_upnp
Feb 6 03:54:12 rc_service: udhcpc 2582:notify_rc start_upnp
Feb 6 03:54:12 rc_service: waitting "stop_upnp" via udhcpc ...
Feb 6 03:54:14 ddns update: ez-ipupdate: starting...
Feb 6 03:54:14 miniupnpd[2615]: version 1.9 started
Feb 6 03:54:14 miniupnpd[2615]: HTTP listening on port 60276
Feb 6 03:54:14 miniupnpd[2615]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 6 03:54:14 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 6 03:54:15 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 06 Feb 2016 03:54:13 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Feb 6 03:54:15 ddns update: retval= 0, ddns_return_code (,200)
Feb 6 03:54:15 ddns update: asusddns_update: 0
Feb 6 03:54:15 ddns: ddns update ok
Feb 6 03:54:15 dhcp client: bound xx.xx.xxx.73 via 37.75.168.1 during 120 seconds.
Feb 6 03:58:40 WAN Connection: Ethernet link up.
Feb 6 03:58:40 rc_service: wanduck 405:notify_rc restart_wan_if 0
Feb 6 03:58:40 kernel: Attempt to kill tasklet from interrupt
Feb 6 03:58:41 wan: [wan0_hwaddr] == [1C:B7:2C:C2:36:F0]
Feb 6 03:58:43 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 6 03:58:44 wan: finish adding multi routes
Feb 6 03:58:49 rc_service: udhcpc 2635:notify_rc stop_upnp
Feb 6 03:58:49 rc_service: udhcpc 2635:notify_rc start_upnp
Feb 6 03:58:49 rc_service: waitting "stop_upnp" via udhcpc ...
Feb 6 03:58:49 miniupnpd[2615]: shutting down MiniUPnPd
Feb 6 03:58:50 ddns update: ez-ipupdate: starting...
Feb 6 03:58:50 miniupnpd[2668]: version 1.9 started
Feb 6 03:58:50 miniupnpd[2668]: HTTP listening on port 56193
Feb 6 03:58:50 miniupnpd[2668]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 6 03:58:50 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 6 03:58:51 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 06 Feb 2016 03:58:50 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Feb 6 03:58:51 ddns update: retval= 0, ddns_return_code (,200)
Feb 6 03:58:51 ddns update: asusddns_update: 0
Feb 6 03:58:52 ddns: ddns update ok
Feb 6 03:58:52 dhcp client: bound xx.xxx.xxx.37 via xx.xxx.xxx.1 during 120 seconds.
Feb 6 05:31:35 rc_service: httpd 2113:notify_rc restart_webdav
Feb 6 05:31:37 WEBDAV Server: daemon is stoped
Feb 6 05:31:37 NAT Tunnel: AAE Service is stopped
Feb 6 05:31:37 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Well, found a command to clear NVRAM - done that, and flashed the newest Merlin firmware. Configured Wifi, made 1 port forward and enabled DMZ. Thats it.
Last change before I will return this!
If it is faulty, which router would you guys recommend? Is it this model that is crappy - seems to be more ASUS models with weird bugs!
So if not ASUS - I might go for a Ubiquiti edge router lite and an AP. Any pros/cons for this?
Do a factory reset always AFTER the update/change of firmware! Before it's completely useless... :rolleyes:
AND: Did you re-configure the router after the factory reset manually? No restore of old settings (expect via John's NVRAM save/restore tool)?
So, now all connections dropped and had to restart the darn thing!
The log shows the date of today, but then interupted with a date in August!:
Feb 6 12:15:24 dhcp client: bound 83.137.126.37 via 83.137.126.1 during 120 seconds.
Feb 6 12:15:24 miniupnpd[1606]: HTTP listening on port 46347
Feb 6 12:15:24 miniupnpd[1606]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 6 12:17:36 dnsmasq-dhcp[453]: DHCPREQUEST(br0) 192.168.1.95 04:69:f8:6a:19:8c
Feb 6 12:17:36 dnsmasq-dhcp[453]: DHCPACK(br0) 192.168.1.95 04:69:f8:6a:19:8c MichaeliPadAir2
Feb 6 14:50:22 dnsmasq-dhcp[453]: DHCPACK(br0) 192.168.1.95 04:69:f8:6a:19:8c MichaeliPadAir2
Feb 6 15:04:48 dnsmasq-dhcp[453]: DHCPREQUEST(br0) 192.168.1.95 04:69:f8:6a:19:8c
Feb 6 15:04:48 dnsmasq-dhcp[453]: DHCPACK(br0) 192.168.1.95 04:69:f8:6a:19:8c MichaeliPadAir2
Aug 1 01:00:11 syslogd started: BusyBox v1.20.2
Aug 1 01:00:11 kernel: klogd started: BusyBox v1.20.2 (2015-12-24 13:54:49 EST)
Aug 1 01:00:11 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #2 SMP PREEMPT Thu Dec 24 14:06:59 EST 2015
Aug 1 01:00:11 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug 1 01:00:11 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 01:00:11 kernel: Machine: Northstar Prototype
Aug 1 01:00:32 miniupnpd[675]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 01:00:32 dhcp client: bound xx.xxx.xxx.37 via xx.xxx.xxx.1 during 3162 seconds.
Aug 1 01:00:33 ntp: start NTP update
Feb 6 15:25:51 rc_service: ntp 674:notify_rc restart_upnp
Feb 6 15:25:51 miniupnpd[675]: shutting down MiniUPnPd
Feb 6 15:25:51 miniupnpd[686]: HTTP listening on port 36055
Feb 6 15:25:51 miniupnpd[686]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 6 15:25:52 rc_service: ntp 674:notify_rc restart_diskmon
Feb 6 15:25:52 disk_monitor: Finish
Feb 6 15:25:53 disk monitor: be idle
Feb 6 15:26:04 dnsmasq-dhcp[438]: DHCPREQUEST(br0) 192.168.1.43 c0:ee:fb:28:ac:69
Feb 6 15:26:04 dnsmasq-dhcp[438]: DHCPACK(br0) 192.168.1.43 c0:ee:fb:28:ac:69 android-c62f71a70ba8abcf
Faulty device or a fix of some kind?
