RT-AC87U, WPS is disabled, but it looks like not on 5 Ghz
rebelion76
Hello!
I have a problem with my RT-AC87U. I disabled WPS in web-interface, but wifi-devices sees 5GHz-net like WPS-available.
What i did : test 3 firmware (last from site, beta from support, last from Merlin, now i am using it) . Ofcourse, i did factory reset after every firmware upgrade.
It not helps.
I read some topics in this forum and test some command, so if i
do
qcsapi_sockrpc set_wps_configured_state wifi0 disabled
qcsapi_sockrpc rfenable 0 wifi0
qcsapi_sockrpc rfenable 1 wifi0
on main system or restart hostapd on quantenna, problem going away.
But only before restart. After restart it' going again.
Any decision?
Thanks.
It's a known issue like they say... and it won't get fixed unless quantenna does it and provide that fix to ASUS
2 slobodan:
I haven't device with wifi on which i can install this. But later i will try to check, thanks.
2all:
If this a known issue, is it software or hardware? Do you have it on your devices?
I know at least one customer, who hasn't (from his words in another forum) Why it so? We compared result of
qcsapi_sockrpc get_info wifi0
Build name: v37.3.0.50
Build revision: 34345
Build type: GPL
Build timestamp: 1440061870
Platform ID: 432
Hardware ID: QV840
Hardware revision: bbic4_rev_a2
Band: 5GHz
Kernel version: 2.6.35
Calibration version: disabled
DC/IQ cal version: V8.1
Power cal version: V8.1
MuC firmware: qtn_driver.qtn_ruby.0.bin
DSP firmware: rdsp_driver.0.bin
AuC firmware: auc_driver.0.bin
MAC address 0: **:**:**:**:**
MAC address 1: 00:00:00:00:00:00
U-Boot version: v37.3.0.26
All parameters are the same, but he has hardware revision: bbic4_rev_a1
@ASUS_ASUSWRT as you can see the issue is solvable by simply adding the:
into a script that runs on each device powerup/reboot/start... Not that difficult and no need to wait for quantenna to fix the mess ;)
