Release RT-AX58U 3004.388.9_2 and device binding problem
ILampa
Hi everyone. I have a strange problem with device binding since upgrading to 3004.388.9_2 on my RT-AX58U. The topology is in an AI mesh with the 58U as the main node and an RT-AC66U B1 running 3004.386.14_2 as the secondary. At some point in the past after upgrading the main node I decided to bind a few devices, which are in the "gray" area distance wise, to the main node. After some time I discovered that ALL devices are now bound to the main node! Trying to unbind them does nothing, both in the WebUI and Asus app on my phone. In other words, impossible to reconfigure binding. Hitting the optimisation for nodes or devices does nothing either.
Has anybody else seen this? Is there a command line option to unbind? Some of the devices are so close to the secondary that they will connect to that node, but show the orange exclamation and hitting unbind does nothing, as mentioned.
Update: After searching a bit better I found an article pertaining to binding and how to "reset".
Command: nvram set sta_binding_list="<AA:AA:AA:AA:AA:AA>1>"
reboot
That cleared the binding list and I can now assign bindings in the UI, both web and app.
