RT-AX68U - No internet after firmware update
Bolin
Running Merlin 386.4.0 and wanting to update to latest 386.5.2 however whenever I update I end up with no internet connection.
I have tried a reset then restore settings, again I have no internet.
I am aware that I can likely do a factory reset, however I have quite few settings which I do not really want to lose as it would take me time and hassle to enter them again.
Is there any way I can get this working after an update?
Are you sure you used the file for an AX68U and not an AX86U? Very easy to get those letters twisted.
Absolutely certain.
RT-AX68U_386.5_2_cferom_pureubi.w
I have tried this about 5 times now, and each time have had to revert back to 386.4.0 to get it working again.
Sadly, yes. I say sadly as I know what your next comment will be, hence my original question. :)
Clearly something in my CFG is disagreeable, I just wondered if there was a way around it?
So, if I am honest, it's probably the odd setting I have no idea I changed :) as well as some Mac/IP bindings, AIMesh setup and samba share. Off the top of my head
It is proably the Aimesh that is messing it up so you may want to redo that after update.
DHCP/custom client list can be backed up/restored with WinSCP and there is a portable version lower down on that page if you don't want to install.
Enable SSH on the router then set WinSCP to SCP protocol then go to the /jffs/nvram
DHCP/IP reservation is file dhcp_staticlist
Client list is custom_clientlist
The other files you want may be in there too.
What you see in WinSCP:
Thank you for that, I have made a backup of those files. I wonder is there one which would save the settings for "USB Application - Network Place (Samba) Share / Cloud Disk" ?
