Hello,
I recently upgraded my motherboard to MSI 690 tomahawk which has an intel AX210 card.
I have an Asus RT-AX86U router, with a gigabit fiber connection. Latest Merlin 386.4
OS: Windows 11.
On 5 GHZ band my download speeds are between 0.1-30 Mbps and upload speed is 650-720 Mbps. I went through all old AX210 drivers - no change
I have tried all the possible settings in my router:
1. Wireless Mode AX only, N/AC/AX mixed, Auto
2. Channel bandwidth 160 Mhz, 20/40/80/160, 20, 40, 80.
3. Control channel Auto with auto select DFS channels, when i manually set channel 100, the download seems stable to 120-130 Mbps and upload 200 Mbps. - but it's still very far away from how it should perform.
all combinations of the above.
4. I tried changing the wifi antennas of the ax210 card - same result.
On 2.4 ghz band, i get 80 Mbps download and 85 upload - speed is normal compared with other devices in the same room.
On 5 ghz band, other devices, in the same room, 1 inch closer to pc have download speeds between 500-600 and upload speeds between 600-650. Even laptops with AX201 wifi card.
Now, the logic tells me it's not routers fault but OS/motherboard/AX210/ AX210's antennas. However, setting the channel manually in router gives better results only for this AX210 card, which i find it weird.
Has anyone encountered this weird situation with AX86U and AX210 cards?
Thanks,
OS: Windows 11.
Thanks,
