YazFi Some devices can't connect to guest 5GHz after upgrading to Merlin 3004.388.9 on AX86U
adri
I'm a big fan of all the work people in this forum have done, my network has been humming away for most of the past 5 years. But today I upgraded to the latest Merlin 3004.388.9 firmware update on my AX86U and things went south. When it came back up:
  • many of my devices (Amazon Echos, IP cameras, some smart home devices) can no longer connect to 5GHz guest WiFi - they see the SSIDs but time out trying to connect
  • those same devices can connect to my main 5Ghz SSID
  • some devices (phones, laptops, desktops) can connect to the 5GHz guest SSs
  • I hadn't changed any settings before upgrading
  • I'm not seeing anything in the syslog when the problem devices try to connect
  • I tried rebooting the router and the devices multiple times, removing and re-adding the network to the devices, and changing the SSIDs
  • I tried uninstalling YazFi and connecting, with no luck. Reinstalling did not fix the problem either.
Idk if this is a YazFi issue, a Merlin issue, or a PEBKAC issue (PEBKAC seems likely since I've never really had problems like this with Merlin's firmware). I really, really don't want to do a factory reset (although in the 6+ hours I've spent trying to figure this out so far, I probably could have fully reconfigured the router).
It seems like it must be a 5Ghz radio issue, I changed a few settings (marked below with *) to recommendations I found here, to no effect. Please let me know if anything stands out:
General:
Enable Smart Connect Off*
Band 5 GHz
Network Name (SSID) spiderweb
Hide SSID No
Wireless Mode Auto
802.11ax / WiFi 6 mode Enable
WiFi Agile Multiband Enable*
Target Wake Time Enable*
Channel bandwidth 160 MHz*; Enable 160 MHz checked
Control Channel 36*
Extension Channel Auto
Authentication Method WPA2/WPA3-Personal
WPA Encryption AES
WPA Pre-Shared Key Very Strong
Protected Management Frames Capable
Group Key Rotation Interval 3600
Professional:
Band 5 GHz
Enable Radio Yes
Enable wireless scheduler No
Set AP Isolated No
Roaming assistant Disable
Enable IGMP Snooping Enable
Multicast Rate(Mbps) Auto
AMPDU RTS Enable
RTS Threshold 2347
DTIM Interval 3*
Beacon Interval 100
Enable TX Bursting Enable
Enable WMM Enable
Enable WMM No-Acknowledgement Disable
Enable WMM APSD Enable
Optimize AMPDU aggregation Disable
Modulation Scheme (WiFi 5) Up to MCS 11 (NitroQAM/1024-QAM)
Airtime Fairness Disable*
Multi-User MIMO Disable*
OFDMA/802.11ax MU-MIMO DL/UL OFDMA + MU-MIMO*
802.11ax/ac Beamforming Enable
Universal Beamforming Disable*
Tx power adjustment Performance
I have the full YazFi diagnostic dump and can post it here if the settings above look ok. Nothing obvious popped out at me when I looked at it, but it's entirely possible I missed something.
Thank you in advance for any help!
~ Adriana
Also, switching the authn method to WPA2-pesonal did not help, nor did enabling Smart Connect.
By any chance do you have DFS channels option checked under the Wireless-General tab? If so try uncheck it and try to connect to 5G again. If it works again you can enable DFS again but you might to change the control channel if it keeps disconnecting on '36' while set to Auto.
I don't think I do, that option disappears when I manually set a control channel. If I look at Systemj Log -> Wireless Log, it says "DFS State: PRE-ISM Channel Availability Check (CAC)" (and then " In-Service Monitoring (ISM)") when I set a 160MHz channel width, or "Idle" when I set it to 80MHz or disable 160MHz. A few more devices can connect when I change the channel width to anything besides 160, but still not all of them.
I tried downgrading to 388.8_4 and still the same issue. Could it really be dnsmasq if the devices aren't even able to authenticate with wifi? They don't seem to get to the stage of making a DHCP request. Regardless, I'm gonna switch the important devices over to 2.4GHz for now, I guess.
What version of YazFi are you running?
When uninstalling YazFI you may need to go in and manually remove, using SSH (PUtty, WinSCP, etc.), the YazFi remnants that don't get deleted by an uninstall. Check the various directories in the /JFFS/ folder for any YazFi leftovers. Reboot the router after fully uninstalling YazFi.
You might need to update to the YazFi Develop version (YazFi 4.4.5).
/jffs/scripts/YazFi develop
/jffs/scripts/YazFi forceupdate
At the end of the day, sometimes strange issues are only fixed/resolved by performing a hard factory reset and manual reconfiguration (do not import a saved router.cfg file). Many times a hard factory reset and manual reconfiguration is faster than spending hours trying to figure out and troubleshoot the strange issue(s) one is experiencing.
Edit to add: And try the usual troubleshooting steps if you haven't done so already.
Avoid using special characters in SSID's and WiFi passwords as a test.
Test with short SSID's and passwords.
If possible instruct the wireless client device to forget all prior saved WiFi connections.
Reset the WiFi client device and try to connect it to the YazFi guest WiFi network.
Doublecheck all YazFi settings including DNS entries if any to ensure they're valid.
Make sure to use unique IP addresses in YazFi.
On some Asus routers the 1st Guest Network is treated differently (for AiMesh) than networks 2 and 3, try using Guest Network 2 and 3 rather than the first Guest Network.
If you have any YazFi custom firewall scripting or YazFi manual WiFi client IP address reservations, remove those scripts/reservations reboot the router.
And as a reminder YazFi does not work on AiMesh or AP nodes, it is main router only.
Protected Management Frames enabled caused big problems here. Most clients could not connect. When I disabled it, all was well.
@bennor thank you for the kind advice. When I uninstalled YafFi, I did not remove the config files & scripts, so that is worth a try, as is upgrading to the dev version (I'm on 4.4.4, which is the latest AMTM offers). I have done most of the troubleshooting you suggest, and you are 100% correct, if I had done a factory reset after spending an hour futzing around with no success, I would definitely have saved myself some time. Sometimes determination comes back to bite me (it was working fine before!); I will keep this in mind for the next mystery.
One other bit of information, nearly all of my YazFi devices have assigned IPs and hostnames in the appropriate subnets via the dnsmasq.postconf script, but a few of them consistently end up on the wrong subnet (on 2.4 GHz) after connecting even though they supposedly are using DHCP. I've seen that happen before tho, so idk if it's related, but it's another data point for someone who goes down this road and is more stubborn than me (don't do it!).
@jrichard326 thank you for the tip, I will try that first before getting more drastic. If that doesn't work, I'll try uninstalling/reinstalling/upgrading YazFi, and if that doesn't work, I promise to throw in the towel and do a reset (unless I hear any other suggestions). All of this, of course, after my housemate goes to sleep.
Thanks again!
~ adri
Couple of suggestions. Make sure your various WiFi both main LAN and Guest Network SSID's and their passwords are unique.
Make sure to remove or delete any previously saved WiFi connections to your router on each of the WiFi devices you are connecting to YazFi.
If using Smart Connect in the Wireless > General section, try disabling that feature and configuring each WiFi band independently with unique SSID's and passwords.
On a side note. I've experienced Amazon Echo clients trying to connect to the wrong WiFi because it was previously connected to a different WiFi ban on the router. Had to not only reset the Amazon Echo but had to go online into the Amazon account settings and delete the previously saved WiFi connections. What would happen is the Amazon Echo device would connect to a previously saved main LAN WiFi connection first due to the main LAN WiFi being active first before the Guest Network WiFi became active when the router was rebooted or powered on.
I tried ...
  • Disabling protected management frames (I had to switch to WPA2-personal and disable wifi agile multiband to do it) - didn't help
  • Upgrading YazFi to 4.4.5 dev - didn't help
  • Upgrading to Merlin 3004_388.9 - didn't help
  • Doing a factory reset - didn't help (!)
What finally did it was ... switching from WPA2/WPA3-personal to WPA2-personal in the guest network configuration. Derp. I swear it was working before on 2/3, but hey, it's working now and I have a fresh new configuration. The only thing is my Wireguard clients are not connecting to my VPN; I backed up and restored the keys as documented here but something is still not right. I'll fight with it for a bit longer, but if I have to cut new keys it's not the end of the world. But otherwise my network is slowly returning to normal.
@bennor I've seen that happen with my Echos before and had to do the same thing, but they seem to be cooperating now. Lately it's a rogue IP camera assigned to one of my YazFi subnets that keeps sneaking onto my main subnet somehow. It seems to be ok since resetting the router, but I'm keeping an eye on it.
Also for good measure, I disabled Smart Connect and split my main 5g & 2.4g nets (I didn't have any 2.4g devices on my main anyway). If nothing else, researching the optimized wireless settings has given me a speed boost, my link for my laptop is at 1200 Mbps, up to 2400Mbps when it connects at 160MHz (not sure why it doesn't consistently, but my ISP connection is only 500Mbps anyway).
Thank you for the suggestions!
~ adri
