RT-AX86U pro log message
erik
I recently updated to 3006.102.7_2 from 3004.388.8_4.
I did a full factory reset and set the router up as new.
All works perfect but i get the following message in the log:
Mar 27 09:35:34 Mastiff: Got AAE_SIG_REMOTE_CONNECTION_TURNED_ON
webaccess from Wan is OFF and SSH is disabled.
Can anyone tell me why i get this message, thanks in advance.
Disable the Asusnat tunnel:
Administration - Tweaks > Disable Asusnat tunnel = Yes.
