RT-AX86U Pro random reboots
DryGoldFish
Hey guys,
Since a few weeks my RT-AX86U Pro is rebooting a lot when my PC is turned on and also at other random moments.
When it restarts it also resets the date to Jan 1 and then goes back to the normal date.
It happened on the stock firmware, I flashed the Merlin software a few days ago but it keeps happening.
These are the events before, during and after the reboot.
Thanks in advance,
Chris
There are some flash errors in the reboot log.
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe00800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe01000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe02000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe02800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe03000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe03800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe04000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe04800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe05000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe05800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe06000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe07000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe07800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe08000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe08800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe09000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe09800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0a000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0a800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0b000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0b800
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0c000
Jan  1 01:00:21 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xfe0c800
Nope the router is in a technical room. And the router does not reset every time my PC gets connected. Today it did not happen for example. Yesterday it did.
