I'm not going to order anything new and see how this works for a bit. Seems like a much better setup with the AX86U upstairs with better reach to the devices that get used most frequently.
This is very helpful and how I have things set up now, thanks! It's connected via 5G and signal strenth is around -45. Printer and ATA appear to be working. I'm pretty confident that the AX86U, positioned where it is now, will provide acceptable coverage to wherever I need. I do not recall exactly why I didn't try it positioned here when I got it. Likely because I didn't know I could set up the 2nd one as a media bridge and not wanting the printer upstairs.If single RT-AX86U is good enough for wireless coverage - you have an easy and free solution. The AX router upstairs, remove this AiMesh, configure the AC router as Media Bridge downstairs. Connect your Printer and VoIP to it and test if everything works as expected.
You mean physically a floor directly under the main router would be bad? The lower one is probably a floor below and 10 feet to the right of the upstairs one. Is that far enough staggered? What happens if they aren't staggered enough?Yes, seems so.
Another option to consider... configure the downstairs AC68U node in Media Bridge Mode to connect wired clients only. The AC68U will use all of its WiFi for the uplink to the upstairs router. Be sure to not locate the AC68U directly under the upstairs router... stagger them apart.
OE
Signal is -46, printer and ATA use almost no data. Based on what OzarkEdge said, I was thinknig maybe there's some sort of persistent connection/data flow between the 2 routers that might cause problems if they are not "staggered".You have GUI with connection information available in Media Bridge mode. Why don't you look there? You set this router in Media Bridge mode yourself, no? How much bandwidth and traffic a Printer and VoIP ATA will need anyway? Sometimes people focus so much on advice online that forget simple and obvious things...
We use essential cookies to make this site work, and optional cookies to enhance your experience.
