After the last UK storm I found I was getting a lot of internet dropouts so factory reset the router RT-AX88U, upgraded to the latest firmware, and reinstalled my settings.
[I'm on EE full fibre and the connection settings have worked solidly for the last two years, and before that the same settings worked on BT]
Since the upgrade I've had a weird problem that
1 - no browser on any device in my network can connect to any Asus website, except from behind a VPN
2 - ipv6 settings seem correct but there is no ipv6 connectivity
3 - router does not connect to Asuscomm DDNS and says that there has been an "unauthorised registration attempt" for my DDNS username at Asuscomm
4 - router cannot connect to the Asus upgrade server
After experimenting with these WAN DNS settings all of which had previously been set to "NO", problems 1 and 2 resolved and connections to Asus websites and ipv6 connectivity now work. I'm not sure which setting now on "YES" is responsible or might be causing other problems!
Problems 3 and 4 persist so still can't connect in the router GUI to the upgrade server or DDNS. I've switched for the time being to NO-IP DDNS which works fine but it is a pain to reset other devices
I have also switched to the latest Merlin fimware, with essentially the same settings, but the problem persists. Any help appreciated!
