Beta RT-AX88U Pro 9.0.0.6.102_37342
OzarkEdge
Part of the Furniture
WebUI release notes:
Firmware version 9.0.0.6_102_37342-gd53d3a6_491-gc7ec3
- Release Note -
Bug Fixes & Enhancements:
- Improved Wi-Fi connection stability, optimized device connectivity and AiMesh pairing experience.
- Enhanced USB backup network performance.
- Optimized Web UI display, language switching, and settings saving process for smoother operation.
- Improved multi-core CPU resource allocation for better stability and speed under heavy load.
- Strengthened system auto-recovery mechanism to ensure stable performance during long-term operation.
OE
I've uploaded it to my ax88u pro (meshed with ax88u node) with about 25 total clients / sensors, 10 hardwired. Running less than an hour. Will report if I notice anything change.
5 hours in, no issues. Everything connecting and moving around as usual - I am getting 1 or 2 less device offline notifications for a smart light outdoor controller on the mesh node that's a bit far from the house, but may be a coincidence. Business as usual.
Few days in. The front yard lights no longer go offline every here and there - pinned to front mesh node ax88u non pro.
Also appear to have better connection stability when on my deck in backyard, where it would have a hard time holding 2.4 on the ax88u pro main, since the last update. Often had to disconnect to move to 5g for internet, and that seems gone.
One issue, the app constantly sends notifications about new devices coming online, even though they are not new/known max addys. Unsure if the FW affects that, but it started when I moved to beta
If it bothers you turn off notifications in the app. I had the same thing on the AX86U Pro and the Android app.
Thank you. I'll leave them on for now to continue to observe the changes.
Do you mean you see the same thing with the ax86u and it's beta firmware?
Yes. This beta seems to be quite stable. I believe the adaptive QOS works better per my basic testing and use. Should be the same for the AX86U Pro as well.
This beta is no longer offered in the webUI here.
Beta over... 88U Pro/86U Pro Release overdue!
I want my input sanitization mechanism strengthened and I want it now! :D
OE
Use hand sanitizer before typing on your keyboard. You might still have some left from the pandemic era (I still do).
