RT-AX88U Setup
PainKiller89
All,
Does WiFi 6 need to be enabled for 2.4ghz and 5ghz? What are some tweaking you guys recommend to make the connectivity better and performance improvements. I am also using link bonding with my NAS to increase the throughput. Any suggestions will be appreciated it.
Have a look in the link in my signature below for the M&M Config and the Nuclear Reset guides for some suggestions on getting a working/stable router first.
Afterward, the suggestions offered can be compared to the baseline of what works for 'most'. :)
I'm not suggesting that all the steps in the guides need to be performed at this time, but it would ensure that the firmware, the hardware, and the clients are all at their expected defaults and should then play nice together. :)
In most cases, unless you are really pushing it, link bonding won't get you much and in some cases may actually reduce the throughput. Depending on the NAS, the FW and other factors, there are a lot of things to consider. Is all your traffic local and your devices are all connected to the 8-port switch in the router?
You don't need to enable WiFi 6 unless you WiFi 6 capable devices :)
In general, the router should work out of the box. "Tweaking" is usually only necessary if you need to make adjustments for your environment or if you have specific devices with specific issues. Many people do turn off "automatic" functions, like channel selection, though. Not sure what the default setting is for those anymore as it has been a while since I've reset.
Oh i didn't know about the throughput with using bonding. Yeah all traffic is local and all of devices are connected to the 8 port switch on the router.
