RT-BE86U - Severe Gaming Desync/Lag only fixed by Factory Reset (Reboot does not help)
byTrunK
Hi everyone,
I’m reaching out because I’m hitting a wall with my ASUS RT-BE86U and I suspect there might be a firmware bug or a resource handling issue specific to this model.
The Setup:
  • Router: ASUS RT-BE86U (Stock Firmware).
  • ISP: Digi Spain (1Gbps Fiber, PPPoE connection).
  • Main Usage: Competitive Gaming (Call of Duty: Black Ops 7, EA FC 26) on PS5.
  • Current Settings: Adaptive QoS is Enabled. I have also tried Port Forwarding, but the issue persists.
The Issue:
I experience massive desync and "heavy gameplay" (shoot first/die first, players skating) after the router has been running for a while.
  • Ping: Stable and low (approx. 20ms).
  • Packet Loss: None reported by game/tests.
The Anomaly (Why I'm posting here):
  1. Rebooting the router (power cycle) or the ISP modem (ONT) does NOT fix the issue. The desync persists immediately after the reboot.
  2. Factory Resetting (Hard Reset/Initialize) the router is the ONLY thing that fixes it. After a factory reset, the hitreg and connection feel perfect and crisp.
  3. However, after few hours of usage, the performance degrades again, returning to the unplayable desync state until I perform another factory reset.
Since a simple reboot doesn't clear the "bad state" but a factory reset does sometimes, it feels like some deep persistent table, cache, or log is getting corrupted or saturated.
Has anyone experienced this behavior with the BE86U? Is there a known degradation issue with the current firmware for this model?
Thanks in advance!
Have you tried not using any QoS settings (adaptive interference?)... your router and Internet service ought to be plenty fast without it.
OE
Yes, I have tested it.
I ran the router with QoS Disabled, AiProtection OFF, and Traffic Analyzer OFF for several days. The behavior is exactly the same:
  1. After a Factory Reset (with QoS OFF): The connection is crisp and perfect.
  2. After approx. 24 hours: The desync/hitreg issues return.
  3. A simple Reboot does not fix it. I have to Factory Reset again to get that "fresh" feeling back.
The fact that the performance degrades over time even with QoS Disabled (and the CPU mostly idle).
Adaptive QoS doesn't work on ASUS BE-class routers anyway because of broken Trend Micro bwdpi engine.
