The PyroPath
So, I got myself a new RT-BE92U to replace my old and trusty RT-AX88U. I was using the AX88U with 4 XT8's in AiMesh. 2 of the XT8's are wired into the AiMesh router. 2 others would connect with the wired XT8's over 5GHz backhaul just fine. Since replacing the AX88U with the BE92U the 2 unwired XT8's only want to connect with the AiMesh router (BE92U) and do so on a miserable -88dB. They won't connect to the wired XT8's anymore over 5 GHz. I can disable the 5GHz radio on the BE92U and they will connect to the wired XT8's over 2.4 GHz, but not over 5 GHz. Both the AX88U and the BE92U ran/run the most recent Merlin (AX88U 3004.388.10, BE92U 3006.102.5), but the XT8's are on stock ASUS, latest version 3.0.0.4.388_24753-gcf5aa2f. Any ideas what might be causing this?
