RT-BE92U LAN communication problem with original firmware
redbird71
Router: ASUS RT-BE92U
Firmware: 3.0.0.6.102_38980
So I just bought the above mentioned router and wanted to run some test with the original firmware before installing Merlin. My problem is that any device connected on Lan port 1 can speak to all other devices connected to the other Lan ports, but the devices connected to Lan ports 2-4 can not communicate with each other.
Dual-WAN is OFF and Primary WAN is set to 10G WAN/LAN-1 and I can’t think of any other setting that could possibly have anything to do with it.
My question is: anybody else experiencing this? Is it likely that updating to Merlin will solve this issue?
Thanks in advance.
I guess you have a 'guest network' enabled, with 'device isolation' turned on. (Or any other additional network, with that feature turned on.)
This would (should) normally prevent devices connected to the 'guest network' to 'directly talk to each other' (they can only access the Internet), but unfortunately has a side-effect that the 'fixed LAN ports' also get the same restriction applied.
Remove the 'guest network' (or the other 'network' where you've enabled the feature), and the LAN ports can talk to each other again.
PS: I can't remember if the term 'device isolation' is exactly what ASUS calls it in the GUI, but I hope you understand what I mean...
See also here:
This worked! Thank you so much. I spend like a hole day finding the problem in the first place and the hole morning going through settings.
I understand this will also happen with Merlin firmware?
BTW it's under Network --> Guest Network --> Advanced Settings --> Set AP Isolated
