RT-N 56U Need Help.( BellAliant )
oldman60
Eric.
Moi aussi je suis du Quebec et j'ai besoin d'aide SVP. Je vais ecrire en Anglais
pour la suite..Merci a L'avance.
Gentlemen.
I purchase a RTN56U and also a RTU 66U as my last post describes,
I'm trying to remove the Actiontec R1000 H from Bell Aliant for the system
I have 3 HD tv's hooked up now , 1 on RJ45 cable and 2 on Coax from a previous install...My dilemma is that both of my 2 new routers don't have a coax connection to give me TV in the basement....What to do now if I want to use the RTN 56U , How can I make this work for connection ????
Thank You for your time , its greatly appreciated/
Merci pour votre temps, tres apprecier.
Regards
Salutation.
Oscar
Nova Scotia.
Ps.. Please keep simple in Help post as I am just a NEWBIE in the game....
Eric.
Gentlemen.
Regards
Salutation.
Oscar
Nova Scotia.
The router won't replace your modem - you will still need to use a modem from Bell.
Unfortunately I'm not familiar with this modem (Bell uses Sagecom and Cellpipe here in Quebec), or how Bell works in Nova Scotia. Here in Quebec, they use VDSL for their FibeTV service, which will have the TV on a PPPoE login, and the Internet access on a separate PPPoE login.
You could try asking your question on the DSLReports forums (http://www.dslreports.com) if no one else here knows. They have a Bell forum there where you might find other Bell Alliant users who might be able to help you.
