RT-N18U Merlin testing Build by john9527
z1022
Build 376.47 from john9527
Wifi cannot enable.
I'm afraid we're quickly going to exceed my abilities here....but we'll give it a go. How about starting by zipping up the syslog and attaching it here. Maybe we can get it figured out with 'group' think :-)
I will do it after I back to home. Can you tell me how to zipping up the sysolg ?
Well, the syslog clearly shows the failure.....looks like a bunch of modules are hit, including the two that failed with the attempt at compiling for a single processor.
Jan 1 08:00:15 kernel: wl_module_init: passivemode set to 0x0
Jan 1 08:00:15 kernel: wl_module_init: txworkq set to 0x1
Jan 1 08:00:15 kernel: BUG: Your driver calls ioremap() on system memory. This leads
Jan 1 08:00:15 kernel: <4>to architecturally unpredictable behaviour on ARMv6+, and ioremap()
Jan 1 08:00:15 kernel: <4>will fail in the next kernel release. Please fix your driver.
Jan 1 08:00:15 kernel: ------------[ cut here ]------------
Jan 1 08:00:15 kernel: WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x8c/0x144()
Jan 1 08:00:15 kernel: module: wl bf037000 4348789
Jan 1 08:00:15 kernel: module: igs bf02d000 12935
Jan 1 08:00:15 kernel: module: emf bf023000 16346
Jan 1 08:00:15 kernel: module: et bf00b000 63944
Jan 1 08:00:15 kernel: module: ctf bf000000 17519
Jan 1 08:00:15 kernel: Modules linked in: wl(P+) igs(P) emf(P) et(P) ctf(P)
Jan 1 08:00:15 kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c00616e0>] (warn_slowpath_common+0x4c/0x64)
Jan 1 08:00:15 kernel: [<c00616e0>] (warn_slowpath_common+0x4c/0x64) from [<c0061714>] (warn_slowpath_null+0x1c/0x24)
Jan 1 08:00:15 kernel: [<c0061714>] (warn_slowpath_null+0x1c/0x24) from [<c0045f30>] (__arm_ioremap_pfn_caller+0x8c/0x144)
Jan 1 08:00:15 kernel: [<c0045f30>] (__arm_ioremap_pfn_caller+0x8c/0x144) from [<c0046050>] (__arm_ioremap_caller+0x50/0x58)
Jan 1 08:00:15 kernel: [<c0046050>] (__arm_ioremap_caller+0x50/0x58) from [<bf15de04>] (wl_attach.clone.23.clone.24+0x174/0x5b4 [wl])
Jan 1 08:00:15 kernel: [<bf15de04>] (wl_attach.clone.23.clone.24+0x174/0x5b4 [wl]) from [<bf20f740>] (wl_pci_probe+0x88/0xac [wl])
Jan 1 08:00:15 kernel: [<bf20f740>] (wl_pci_probe+0x88/0xac [wl]) from [<c01736dc>] (pci_device_probe+0x5c/0x80)
Jan 1 08:00:15 kernel: [<c01736dc>] (pci_device_probe+0x5c/0x80) from [<c0190944>] (driver_probe_device+0x78/0x174)
Jan 1 08:00:15 kernel: [<c0190944>] (driver_probe_device+0x78/0x174) from [<c0190acc>] (__driver_attach+0x8c/0x90)
Jan 1 08:00:15 kernel: [<c0190acc>] (__driver_attach+0x8c/0x90) from [<c018fba0>] (bus_for_each_dev+0x54/0x80)
Jan 1 08:00:15 kernel: [<c018fba0>] (bus_for_each_dev+0x54/0x80) from [<c0190298>] (bus_add_driver+0x98/0x230)
Jan 1 08:00:15 kernel: [<c0190298>] (bus_add_driver+0x98/0x230) from [<c0190cd0>] (driver_register+0x78/0x13c)
Jan 1 08:00:15 kernel: [<c0190cd0>] (driver_register+0x78/0x13c) from [<c0173944>] (__pci_register_driver+0x44/0xb4)
Jan 1 08:00:15 kernel: [<c0173944>] (__pci_register_driver+0x44/0xb4) from [<c003d5bc>] (do_one_initcall+0x30/0x19c)
Jan 1 08:00:15 kernel: [<c003d5bc>] (do_one_initcall+0x30/0x19c) from [<c008eb78>] (sys_init_module+0x11c/0x1bac)
Jan 1 08:00:15 kernel: [<c008eb78>] (sys_init_module+0x11c/0x1bac) from [<c003dac0>] (ret_fast_syscall+0x0/0x30)
Jan 1 08:00:15 kernel: ---[ end trace 1c898f3353e1b7fd ]---
Jan 1 08:00:15 kernel: wl driver 6.37.14.73 (r448163) failed with code 1
ty extract wl.ko from latest firmware by fmk (firmware mod kit)
I'm not familiar with fmk....can you give me a pointer?
I downloaded the latest source for the N18U, but it looks like it doesn't contain most of the precompiled binaries.
