Hi
I have attached an external USB HDD to the router but unfortunately after a power cut (also after reboot) the "mountpoint" (dont know if thats the right term) changes. Sometimes the router shows my HDD as sda1, sda5, sdb3 and so on, the name changes.
The bad thing about this is, that i created some scripts using the "mountpoints", so if the name changes from sda1 to sda5 my scripts dont work anymore.
Is there a way to manually rename the drives or prevent the router giving them new names?
Or do i have to change my scripts?
I am using Merlins RT-N66U_3.0.0.4_374.33_0, the external harddisk is a 2TB NTFS HDD and I hope there is a way to do it without formatting my harddisk
I also leave my HDD always in the same USB Port.
Thanks in advance!
Thanks in advance!
