RT-N66U - Constant "Authentication Required" prompts
IlChengis
Hello Gents.
Whenever I go to the config page of my ancient RT-N66U (Merlin LTS fork) to do something, the page keeps on popping the "Authentication Required" dialog box, constantly.
Authenticating will give me an autonomy of maybe 45 seconds, only to interrupt my work (and concentration) with a new authorization request.
I've checked the "Auto Logout" setting and determined that changing it to any arbitrary value doesn't seem to make any difference.
Has anyone seen anything similar before?
Thanks in advance.
How long has it been since that router's firmware has been updated/installed or set to factory defaults? These routers often work themselves into a bad state over time. And all kinds of weirdness ensues. It's like the old Windows OS from the '90s. Sooner or later, you just knew you'd have to reinstall and start fresh to get things back to normal.
P.S. Also wouldn't hurt to clear your browser cache or try another browser. Sometimes they get out-of-sync and you get weird problems.
I used to see it happen on a mobile browser like Safari on iOS when switching tabs away from the router GUI, the tab would be suspended and not keep sending the needed keepalive request to the router's httpd server. This would result in a timeout and have to login again. You can try setting this nvram variable to larger values (in seconds) until it stops prompting in most cases.
Bash:
nvram set http_disc_timeout=300
nvram commit
service restart_httpd
I used to have mine set to 900 seconds.
Thank you both for your replies.
I updated recently and reset all settings at the same time. I also switched to a different browser, actually for this very reason... couldn't stand the router tab stealing focus every few seconds on my main browser.
Bash:
nvram commit
Very helpful, thank you Dave. I just SSHed, but I can't see the current value, looks like I don't have that variable in my settings. I poked around, however, and found this:
Bash:
http_autologout=30
Unfortunately, that's in 'minutes', and the default value (visible in the web GUI) is clearly not making any difference. Hmmm...
U asus rt-n66u unsupported firmware. ASUS Wi-Fi 8
B Issue setting up n66u in AP mode ASUS Wi-Fi 2
