RT-N66U Drop Down list + Clients no showing!?
mo418
I have a RT-N66U router. Every drop down list in the GUI do no show up. Is this a common issue?
Also, client list is not showing anything when I click.
I updated to the latest firmware (3.0.0.4.376_1071)
Thanks in advance!
I have a RT-N66U router. Every drop down list in the GUI do no show up. Is this a common issue? Also, client list is not showing anything when I click. I updated to the latest firmware (3.0.0.4.376_1071)
Thanks in advance!
Just a dumb question here, but did you erase the nvram contents when you updated? Sometimes old nvram contents can confuse new firmware. Also, did the firmware flash complete, and tell you it did so and did you give it plenty of time to finish?
I did restore to factory from GUI.
The firmware updated completely (100%), and I let it some time.
I wanted to reset to out of the box state, but don't find how. I did the 5 sec reset button, which is the same as GUI manipulation I guess.
OK, here is what happens.
I can see the new features from the firmware when fresh install (client list, etc) first time I get on the router page.
Then, I manually configure the router as before. First refresh the router page gets (after apply), I lose everything (client list, drop-down menu for static ip, etc)
Like a buggy GUI...(?)
UPDATE
Ok, I think I was not patient enough. I have to click 3 or 4 times on the client list, and then it appears.
Same thing for the drop down list. I have to refresh the router page so I can see one.
Thanks for your support, I'll let you know if everything wrong comes up!
Ok, I need some help again.
Few months ago, Asus ddns died for me (asuscomm.com)
Moment ago, tried to update with latest firmware. Asus DDNS back on track, but many issues with everything else in the GUI.
After lots of trial and error, I have been able to have everything showing correctly in the GUI BUT asus DDNS is now down for me again!
I'm kind of annoyed by setting up everything again and again. It is very long.
May someone help me with this issue please? I really like the Aicloud ddns feature. I used to share music with friends with this.
Haha ok nevermind guys...
I forwarded ports 80 and 443 to a local machine. Though, there was a conflict since those ports are for the default gateway (192.168.1.1) oops
Thanks for your help anyway
This is the best forum for troubleshooting! :)
